Activity Forums Apple Final Cut Pro Legacy FCP 7 Multi-clip question
  • FCP 7 Multi-clip question
    Posted by Christian Stevens on May 27, 2010 at 6:31 pm
    Hi there,
    I’ve worked extensively with FCP 6 but am just now getting into version 7. Working on a project that involves multiclipping I found that if I made an edit and placed a transition there, the next time I went back and changed the active angle the muliticlip would collapse. By collapse I mean I am left with the original master clip (of that angle) instead of a multiclip. This only happens if there is a transition on the edit point. So I ask, is this a new restriction with 7 or a bug?
    Christian
    Asaf Blasberg replied 16 years, 3 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    May 28, 2010 at 11:11 am
    I’m not seeing that behavior here… it’s keeping the multiclip here intact.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Christian Stevens
    May 28, 2010 at 5:56 pm
    Well thanks for the confirmation Jerry. The edit wasn’t that extensive so I’ve made it through just avoiding the issue this time.
    -Christian
  • Asaf Blasberg
    June 2, 2010 at 10:39 pm
    Hi Christian,
    I have the exact same problem. This is awful and I don’t know how to fix this. I have FCP 7.0.2 — anybody know what’s going on?
