Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 install
FCP 7 install
Posted by Tom Fino on July 10, 2013 at 3:58 pmI’m trying to copy FCP 7 from one computer to another. I don’t have original discs.
If anyone can give me instructions I’d appreciate it.
Thanks.Tom Fino replied 13 years, 2 months ago 2 Members · 6 Replies -
Shane Ross
July 10, 2013 at 5:02 pmIt won’t work properly. There are too many FCP resources that get installed throughout the system. In order for it to work right, you need to install from the original install discs
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Tom Fino
July 11, 2013 at 5:44 pmOk thanks. I got it to start the install process, then it says “Installation Failed.” Is it possible I have an incompatible graphics card and that’s why it won’t finish installing? It has an NVIDIA card.
(another computer I have with FCP successfully installed has an ATI card.)Thanks in advance for any advice.
Shane Ross
July 11, 2013 at 6:15 pmIt doesn’t give any reason why the install failed?
Shane
Little Frog Post
Shane Ross
July 11, 2013 at 6:32 pmWell THAT’S helpful. Thanks Apple.
What’s the OS of the computer you are installing it on? What about the one that it worked on?
Shane
Little Frog Post
