Activity Forums Apple Final Cut Pro Legacy FCP 7, gaps, markers bug
  • FCP 7, gaps, markers bug
    Posted by Chi-ho Lee on September 23, 2009 at 4:00 am
    Hey Folks,
    See if this happens with you. Add a marker over a sequence gap. And then ripple delete clip/clips upstream (before this marker) with either in/out/ripple delete or select a clip/clips and then ripple delete. See if the marker over the gap ripples. It is not rippling on my system.
    This looks to be a bug.
    CHL
    Chi-Ho Lee
    Film & Television Editor
    Apple Certified Final Cut Pro Trainer
    http://www.chiholee.com
    Graham Withers replied 15 years, 5 months ago 6 Members · 7 Replies
  • 7 Replies
  • Tom Wolsky
    September 23, 2009 at 8:26 am
    Hi Chi-Ho,
    It works for me. Ripple button’s green, right? I tried it in a few different sequences.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Chi-ho Lee
    September 23, 2009 at 3:57 pm
    Tom, sorry, let me reframe the situation.
    Create a seq with a series of clips. Place a seq marker on top of a clip. Delete that clip under the marker. You should notice that marker stays put and if there are markers down the timeline they will ripple up as expected. But the marker above the clip that was just selected stays put.
    See if you can recreate that.
    CHL
    Chi-Ho Lee
  • Tom Wolsky
    September 23, 2009 at 5:26 pm
    Yes, I can confirm that. Markers above the clip that’s being ripple deleted do not ripple with the rest of the sequence markers. Should be reported. Not sure if it’s a bug, looks kind of bug-like, or if it’s a feature request. Either way, I agree the application should not behave like this.
    All the best,
    Tom
  • Alex Kaloostian
    September 23, 2009 at 7:03 pm
    I am seeing this, too. Markers farther down the timeline will ripple but the marker right over the clip being deleted stays put. But where would you have the marker go? should it go to the end of the previous clip? should it ripple back by the full length of the deleted clip? or should it be deleted completely?
    Im also noticing another related issue- if you have a marker over a gap, and you ripple delete any clip before the gap, all the following clips and following markers will ripple back. HOWEVER- if you delete the last clip before the gap AND any other clips, the marker does NOT ripple.
    Lets say you have clipA, clipB, clipC, gap, clipD. there’s a marker over the gap. If you ripple-delete clipA, clipB, or clipC, the marker will ripple. if you delete clipA&B, the marker will ripple. HOWEVER, if you ripple-delete clipB&C, or A&B&C, the marker will NOT ripple.
    This is a bad one because it’s so inconsistent; it should always ripple or never ripple. I can see people pulling their hair out over this one.
    “I’m Alex Kaloostian, and I approve this message.”
  • Noah Kadner
    September 25, 2009 at 9:21 pm
    Yeah that happens on my system too. I’m using this today to make DVD chapter markers and it’s key they stay where they are relative to the timeline. That’s kind of a bummer.
    Noah
    Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!. Unlock the secrets of the 24p, HD and Final Cut Studio.
    Now featuring the Sony EX1 Guidebook, Panasonic HVX200, and Panasonic DVX100.
    https://www.callboxlive.com
    DSLR Cinematography Blog
  • Morgan Mendieta
    October 9, 2009 at 7:10 pm
    You can turn this on and off. I was having a headache with this. I use markers to mark certain time I need to meet so when my markers kept following my cuts I was going to shoot an apple.
    but if you go to the top right of the working timeline where you have the “snapping” button to the left there is a new button “ripple Sequence marker”
    Hit that button and you are back to normal.
    Hope this helps.
  • Graham Withers
    March 22, 2011 at 2:55 pm
    I also get erratic behaviour from the ripple markers. I love this feature – awesome for producer/client screenings where I can make notes on the timeline, address them later, make my notes in the comment section and then output the markers as text for a “here’s how I addressed your notes master” document.
    BUT!
    Ripple markers have a mind of their own no doubt.
    They respond consistently to insert and ripple in-out edits but no so much with extending clips, selecting clips and cutting them out with command-x, etc…
    Does anyone have a good reference for “when markers ripple and when they don’t?”
    All the guess work really detracts from using them in my workflow.
