Activity Forums Apple Final Cut Pro Legacy FCP 7 crashing when even touching Motion templates
  • FCP 7 crashing when even touching Motion templates
    Posted by Warwick Meade on April 17, 2015 at 4:09 am
    I have a copy of FCP 7 on OS X Yosemite.
    Its has been working sweetly for 4 months now, including using Motion Templates for subtitles, lower thirds etc.
    Yesterday I loaded a trail versions on FCP X so I can get to grips with it.
    Now even when I touch the subtitles in FCP 7 it crashes. i can barely touch a timeline with a motion template on it.
    any thoughts? Its driving me nuts!
    Many thanks in advance!
    w
    Mark Suszko replied 11 years, 4 months ago 3 Members · 3 Replies
  • Shane Ross
    April 17, 2015 at 4:41 pm
    Well it’s obvious. It worked…then you installed FCX…then it didn’t work. FCX is interfering with it.
    In order to have both FCX and FCP 7 (studio 3) on the same computer, you need to follow some specific steps:
    https://support.apple.com/en-us/HT202240
    Shane
    Little Frog Post
  • Warwick Meade
    April 17, 2015 at 8:27 pm
    too true, unfortunately all the instructions include firing up Motion 4, which i can’t do, because motion 4 does not work on OS X.
    am hoping there are prefs i can change or folder structure I can change mutually.
    Hoping to not have to uninstall FCP X, but looking like I may have to.
    w
  • Mark Suszko
    April 17, 2015 at 9:29 pm
    IMBW, but I think an Yosemite OS install breaks Motion 4 and leaves you only able to use motion 5, unless you set up dual boot partitions first. Or am I thinking of Compressor?
