Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 captures HDV without .mov extension
Posted by Alejandro Arriaga on September 16, 2009 at 11:39 pmI’ve just installed FCS 3 and now when I capture HDV into Apple Intermediate Codec, I’m getting text files instead of mov files.
Is this a bug?
or
Is this a new way FCP handles files?what’s going on?
FCP seems to be reading the files fine in the project that I captured from, but if I try to reorganize the files, FCP states that the file isn’t recognized.
I know I can add the extension with automator, but I didn’t have to do this “adding” in the last version.
Thanks for your help…
Never love a filmmaker…
Ron Priest replied 14 years, 9 months ago 10 Members · 14 Replies -
Shane Ross
September 16, 2009 at 11:53 pmCapture HDV as HDV. Apple intermediate is a lossy and BLOATED codec rife with issues. For one, it doesn’t capture TIMECODE…something that is rather important. And the file sizes are nearly double that of native HDV.
If you don’t want to capture native HDV, but as another format, then use ProRes. Larger files, but MUCH BETTER than AIC.
Shane
Read my blog, Little Frog in High Def -
Alejandro Arriaga
September 17, 2009 at 12:26 amShane, thanks for your comment…
I just thought AIC was better than native HDV…
I love Proress (is just the amount of space).
Next time I will use proress.
appreciated
Alejandro
Shane Ross
September 17, 2009 at 12:32 amOh no…Apple Intermediate was the patch that people used to capture HDV as before FCP had native HDV support. You had to use Lumiere HD or HDVxDV to import, and had to do so as AIC.
Shane
Corbin Thomas
September 28, 2009 at 11:05 pmive had the same issues with my capture files having no extension but I did capture my hd footage as apple pro res… final cut 7 and snow kitty os..
what gives?
any help would be appreciated…
thanks!
Ron Priest
October 2, 2009 at 11:05 pmYes, I’m seeing the same problem on my system with newly captured ProRes Files. However, looking back at my older ProRes files captured in FCP 6 before Snow Leopard, I notice those files didn’t have any file extension either. However, they did contain the file type description as “QuickTime movie” as the new ProRes files captured via fire wire (note I said captured not converted) contain the file type decryption of “document” and control clicking (right clicking) on the file and clicking on info shows the file has no extension and the “hide extension” is NOT selected. Further it shows the file being created by TextEdit (which I suppose is the default for document files).
Ron Priest
Videographer
Louisville, KY -
Alvaro Lanciai
October 4, 2009 at 9:07 pmdear friends,
when I capture with snow leopard in apple prores the finder doesn’t recognize te clips as video clips and I cannot change the default application in the file info….also the preview in the finder doesn’t appear and i see all te clip as text files…..
since quicktime has radically changed, i reinstall the old one at:
https://support.apple.com/kb/HT3678?viewlocale=en_USand yesterday I uploaded the player for snow leopard here:
https://www.apple.com/downloads/macosx/apple/application_updates/quicktimeplayer7formacosxv106.htmlbut nothing has changed…any ideas…? Suggestions?
Alvaro
MAC INTEL dual quadcore 3ghz
8gb ram
macos 10.5.8 and 10.6
fcp 7 -
Alvaro Lanciai
November 27, 2009 at 10:13 amdear friends….
i solve the problem with this fast and simple application…
and I rename the prores video files adding the extension .mov
I cannot investigate anymore about snow leopard and fcp relationships….i’ve to finish my videos and so i found something that can solve this bug….if somebody else has other solutions i’m here….
Alvo
8gb ram
macos 10.5.8 and macos 10.6
fcp 7 -
Alvaro Lanciai
November 27, 2009 at 10:14 amdear friends….
Alvo
8gb ram
fcp 7 -
Rafael Amador
November 27, 2009 at 12:17 pmHi Alvaro,
In the lower left corner of the FC export window, there is a button “Hide extension”. You may have it checked in.
rafael
