FCP 7 – Canvas window showing occasional dark green screen – Display resolution problem? Slow drive?
Hi everyone,
Having a problem and I hope someone can help. I’m using FCP 7 and occasionally getting a dark green color in my canvas window. It will come and go, depending on where I am in my timeline. Sometimes, it happens as I’m trying to zoom in on a clip (scale), to the point where I can’t even see what I’m doing. Even if I hit stop on playback, the canvas will still show green (or sometimes, it will divide the canvas screen into multiple sections, showing multiple strips of green at different opacity, with the footage showing underneath).
I have attached 2 photos to illustrate (here below).
However, when I render out a file, the result is perfectly fine. This green color only shows up during my work process (in the canvas).
I was wondering whether this might be because of my display resolution. I know FCP recommends 1280×800. But my iMac doesn’t offer that resolution, so I have it set to 1280×720. Could that be the problem?
Another possibility – I should also mention that I’m booting up my system from an external hard drive (G Drive mobile, 5400 RPM, Firewire 800). Perhaps it’s not fast enough? Just to clarify, this external drive is my boot drive which also contains the actual FCP software that I’m using. The only doubt I have about this possible culprit is that this happens even when playback is stopped.
My content / data is located on a totally separate external hard drive (G Drive, 7200 rpm, Firewire 800).
I tried trashing prefs, but no change.
Also, my footage is ProRes 4444.
Here are spec details of my system:
iMac 27 inch, 3.4 GHz, Intel Core i7, 16 GB RAM 1333 MHz DDR3
Graphics card: AMD Radeon HD 6970M
OS X 10.6.8
Final Cut Pro 7.0.3
Boot drive (external): G Drive mobile, 5400 rpm, FW 800
Content drive (external): G Drive, 7200 rpm, FW 800.
Thanks for any help you can offer.
