Activity › Forums › Apple Final Cut Pro › FCP 7 and X play well together on the same disk?
Posted by Craig Sawchuk on July 25, 2011 at 3:54 pmHas anyone had issues with FCP 7 and X playing nicely together when loaded on the same boot drive, or don’t they co-exist?
Craig
Craig Sawchuk replied 15 years, 2 months ago 7 Members · 8 Replies -
Nick Toth
July 25, 2011 at 4:08 pmI have both together under Snow Leopard. Haven’t seen any issues that I can attribute to them both being on the same drive. They can’t run at the same time so there’s no real interaction between them.
NT
David Battistella
July 25, 2011 at 4:33 pmYou can not run both applications at the same time.
David
______________________________
The shortest answer is doing.
Lord Herbert
https://vimeo.com/battistella -
Michael Sacci
July 25, 2011 at 5:19 pmThere would be no real interaction between them even if they could run at the same time.
Craig Sawchuk
July 25, 2011 at 7:58 pmWasn’t thinking of trying to run them at the same time, only whether being on the same drive might cause any problems. Some have suggested putting them on separate partitions to avoid potential problems…
Craig
Kevin P mcauliffe
July 25, 2011 at 8:04 pmNo problems. You’re good to go.
Kevin P McAuliffe
Creative COW Trainer
kevinpmcauliffe@gmail.com
Twitter: @kpmcauliffe -
Mark Morache
July 25, 2011 at 9:12 pmLikewise… I’ve had no problem with both on the same partition.
I followed Apple’s suggestions for installing them on the same disk.
https://support.apple.com/kb/HT4722
I’m wondering why they even suggested putting them on separate partitions?
I’m calling it FCX. They took the “pro” out, so I will too.
I’ll reconsider after the first upgrade.Mark Morache
Avid/Xpri/FCP7/FCX
Evening Magazine,Seattle, WA
blogging at https://fcpx.wordpress.com -
Alex Gollner
July 26, 2011 at 1:08 pmOn the plug-in developer list, someone on the FCP X team said the reason behind the ‘different partition’ instruction was to make sure no FCP 7 workflows were screwed up by FCS3 apps being moved and renamed by the FCP X installer.
Alex
___________________________________________________
Alexandre Gollner,
Editor, Zone 2-North West, Londonalex4d on twitter, facebook, .wordpress.com & .com
