Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 and Maverick – which external hard drive to use?
  • FCP 7 and Maverick – which external hard drive to use?
    Posted by Sylvie Bolioli on January 29, 2015 at 4:16 pm
    Hello, I’m still using FCP7. When I upgraded to Lion and Maverick, a G-Raid drive containing my whole movie edit was corrupted. I have tried to install a Snow Leopard partition but I cannot use the drive any longer, not even on Snow Leopard. Hopefully I can still copy the files over to a new drive. Is there a different better brand of External Drives I should use?
    Thank you,
    Sylvie
    Sylvie Bolioli replied 11 years, 8 months ago 2 Members · 2 Replies
  • David Roth weiss
    January 29, 2015 at 5:04 pm
    Before you do anything else you should purchase Disk Warrior and run it on your drive. It will be the best $99 you ever spent, and if the drive is corrupted and your issue is not a hardware failure DW will most likely repair it.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Sylvie Bolioli
    January 29, 2015 at 5:06 pm
    Thank you very much David, I will try that
