Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 – 720p footage is not playing back in viewer or canvas ( Image stays frozen)
  • FCP 7 – 720p footage is not playing back in viewer or canvas ( Image stays frozen)
    Posted by Brad Jenkins on July 9, 2011 at 7:40 pm
    Im doing Video assist on set with an Alexa HD cam feeding me a 1280 x 720p 59.94 image. Its capturing fine, but if i try and play something back, the image in the viewer ( or if i drop clip down to timeline the image in canvas) wont playback properly. The image will playback properly on my external directors monitor (Panasonic 1710 broadcast monitor). The image in the viewer and canvas stays frozen while playing back, but when i pause the playback the image will change to the current frame of where the playheads new position is, and when i play it again it will stay frozen on that frame until i pause it again and the image again will catch up to the playhead. I tried to click the RT from unlimited rt to safe rt but that didnt seem to do anything to help. I did have a clip playback at some point in the day yesterday , I didnt really change anything at that time, and couldnt get it back to playing so Im clueless as to whats going on. ANy help would be much appreciated thanks.
    FCP 7
    I’m using a matrox mx02 I/0
    Using the settings – matrox 1280 x 720 60p
    apple prores 422
    17″ macbook pro 2.93 core 2 duo
    6gb Ram
    Annie Biggs replied 12 years, 11 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    July 10, 2011 at 1:56 am
    You have to turn on “Mirror on the desktop” for external monitor and canvas/viewer to all play together. It’s in the Audio/video settings under the A/V devices tab. Is this on?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Annie Biggs
    October 29, 2013 at 3:22 pm
    Thanks so much, I had the same problem as the person above. You solved it!
