Activity › Forums › Apple Final Cut Pro Legacy › fcp 6.0.5 update causes problems
Posted by Sam Woolf on January 12, 2009 at 12:04 pmI’ve just installed the 6.0.5 update and now the canvas in fcp is completly white when paused. When playing the video shows fine, but when stopped you just get white instead of the still frame.
Is anyone else having this problem?
Sam.
Sam Woolf replied 17 years, 7 months ago 3 Members · 7 Replies -
Rafael Amador
January 12, 2009 at 12:27 pmIn the top of the Canvas click the left button and check RGB instead of Alpha.
Rafael -
Sam Woolf
January 12, 2009 at 12:33 pmAhh. Thanks – your completely right!
Now feeling slightly silly.. -
Rafael Amador
January 12, 2009 at 12:40 pm -
Jeffrey Mills
February 24, 2009 at 9:42 pmSam,
Did you have any other upgrade issues. I’m about to upgrade several things to get FCP capibiities for XDCAM EX editing.
FCP 6.0.1 > 6.0.5
OSX 10.5.2 > 10.5.6
QT 7.4.1 > 7.6also upgrades to my Hardware: AJA IO HD & CalDigit HDPro Array
Jeffrey Mills
Sam Woolf
February 24, 2009 at 10:22 pmHi Jeffrey,
As it turned out, the problem was not related to the fcp update. The system is working fine now and I haven’t had any other upgrade related issues.
Fingers crossed, you should be fine!
Sam.
Jeffrey Mills
February 24, 2009 at 10:26 pmSam,
Are you also running the most current system(10.5.6) and QT (7.6)?
Jeff
Sam Woolf
February 24, 2009 at 11:10 pmcurrently on 10.5.6 and qt 7.5.5 – must have missed a qt update – but not because of any issues..
Sam.
