FCP 6.0.4 crashes MacBook Pro when I render sequence
Hi all,
Searched the archive for a similar problem with no luck… lots of render crashes but usually related to export.I’ve been cutting a project at work and have needed to edit at home with my Macbook. 10 min run time with lots of layers, color keys and graphic overlays, it take better then an hour to render when it works. When I go to render a clip or sequence on the mac book intermittently I get a hard crash where the screen wipes transparent grey and tells me to turn off the computer. Early with this same project I was experiencing a jitter or reverse render on my NTSC monitor I have since corrected with field shift filter. Did not catch the upper field fist on the converted HD stuff when I down converted. But if there a clips on the same time line with different field dominance could that cause a problem. As I’m thinking about this right now the problem might be presenting itself when rendering around the spots where I have used older standard def footage from previous projects… same codec though (apple prores hq) hmmm? Also I had a few times where the render was corrupt with lines running through it. It all works great at work using same projectfile and driveson my Mac Pro system.
This has not happened on my macbook computer before this project.
Thing that are different with this project:
-Original footage 1080 60i HD converted to apple prores HQ 720 x 486.
-Combining 480i footage with this new stuff.
– field dominance mixing although all looks correct on ntsc monitor.
– 2 drives being used
– 2 monitor display with project and timeline on secondary monitorSo anyway, what’s the problem? 2 drives? or the monitors? field dominance?All of the above? I’m pretty sure I’ve had drives both on FW 800 as well as both on esata and now split with the same problem. Why would it all work on the system at my office? Could kona be helping with something the Macbook system can not?
Let me know if anyone has any thoughts on this one.
Tom Butler
TKO Productions Ltd
MinneapolisMy system at work:
Mac Pro
3.0 GHz quad intel zeon 8 core
4 gig ram
kona LHe HD/SD external BOB
Geforce 8800 gt 2 dual DVIMacBook Pro osx10.5.4
Intel Core 2 Duo 2.6 GHz Mem GB
4 gig 667 Mghz ddr2 SD ram
17 inch GeForce 8600M GT 512 MB
Running dual monitor 24″ Septer
Both displays 1920 x 1200 Hdwr accel is on. DVI out
Griffen Express card duo esata
2 drives 7200 rpm Lacie 500 gig Iomega 750 gig
mac journled
