Activity Forums Apple Final Cut Pro Legacy FCP 6 won’t play HD for more than 20 seconds-HELP!!!!!
  • FCP 6 won’t play HD for more than 20 seconds-HELP!!!!!
    Posted by Digitaldavey on September 16, 2007 at 8:44 pm
    I am just installed Final Cut studio2 on a G5 dual2 gig with 2.5 gigs of ram. I have media imported from P2 on a 500gig usb2.0. I was working in HDrt for a while and now when i relinked to the HD (1080 30p) I will only play for about 20 to 30 seconds then it skips and stalls. Is there a buffering setting I can Adjust? Is my system underpowered? Is it the hard drive? Anyone have a suggestion? Keep in mind I have no budget!
    I have the project director sitting in the room with me and we are both tearing our hair out.
    Please Help!!!!!!!
    Davey
    Chris Borjis replied 18 years, 11 months ago 7 Members · 7 Replies
  • 7 Replies
  • David Roth weiss
    September 16, 2007 at 9:11 pm
    USB drives are suitable as media drives as they cannot sustain the necessary throughput for playback without dropped frames.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Steve Eisen
    September 16, 2007 at 10:00 pm
    David meant to say are NOTsuitable. I would reccomend you get a G-Raid drive.
    Good luck!
  • Walter Biscardi
    September 16, 2007 at 10:42 pm
    [digitaldavey] “I have media imported from P2 on a 500gig usb2.0.”
    USB drives are not suitable for video editing as you have just discovered.
    You will require at least a FW800 drive, preferrably a RAID. Lacie makes some nice small FW800 RAID’s.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Viktor David
    September 16, 2007 at 10:51 pm
    We had issues with HD files playing back from a G-Raids – they are designed for SD (DV or DV50). We were forced to upgrade to 15K 4 Cheetas SCSI Raid 0, which was quite expensive. A colleague of mine has been using E-SATA raid to cut HDCAM 4:4:4 footage pretty successfully.
    Vic
  • David Roth weiss
    September 16, 2007 at 11:44 pm
    [Steve Eisen] “David meant to say are NOTsuitable.”
    Yes I did… Thanks for correcting that one Steve…
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Shane Ross
    September 17, 2007 at 8:16 am
    [Vic David] “We had issues with HD files playing back from a G-Raids – they are designed for SD (DV or DV50). We were forced to upgrade to 15K 4 Cheetas SCSI Raid 0, which was quite expensive. A colleague of mine has been using E-SATA raid to cut HDCAM 4:4:4 footage pretty successfully.”
    Vic, we aren’t talking HDCAM 4:4:4 here, or even HDCAM 4:2:2…we are talking about DVCPRO HD footage. For this, G-Raids, Lacie BIg disks, CalDigit Firewire VR drives…basically any firewire 800 hardware raided hard drive will do. I use G-Raids and the Firewire VR for this work all the time.
  • Chris Borjis
    September 17, 2007 at 3:22 pm
    [walter biscardi] “You will require at least a FW800 drive, p”
    Walter I’m curious, have you ever edited shows in DVCPRO-HD directly from a non-raid FW800 drive?
