Activity Forums Apple Final Cut Pro Legacy FCP 6 will not launch
  • FCP 6 will not launch
    Posted by Patrick Bennett on September 16, 2008 at 9:32 pm
    Hello,
    I’ve got a problem and have yet to find a solution after extensive searching.
    I was trying to fix a corrupted sequence in FCP 6.0.4 and almost had it working again by removing the capture files and reopening the sequence. After having problems reconnecting the media, I restarted the computer,
    After booting up, I could no longer open FCP. All it does is bounce once in the dock, then nothing. No error, no warning, no spinning beach ball. I’ve trashed the preferences, repaired permissions, tried FCP Rescue 6. Nothing has worked so far.
    I’m using a Dual 2.8 Quad with 2 GB ram OS 10.5.4, FYI.
    Thanks in advanced!
    David Roth weiss replied 17 years, 10 months ago 3 Members · 4 Replies
  • Fred Vanderpoel
    November 8, 2008 at 2:50 pm
    Hi Patrick,
    I have the same problem.
    Did you ever get this resolved?
    If so, how?
    Much appreciated,
    Fred
  • David Roth weiss
    November 8, 2008 at 4:19 pm
    Fred,
    Always try these three things. If they don’t work then come back for other ideas.
    1. Trash Preferences
    2. Use Disk Utility Permissions
    3. Run Disk Warrior on your system drive. If you don’t have Disk Warrior, get it, as sometimes it’s the only fix there is.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Fred Vanderpoel
    November 8, 2008 at 5:40 pm
    Hi David,
    thank you for your response!
    Used attic to trash prefs;
    repaired disk permissions;
    used Disk Warrior to repair directory (13%);
    still FCB will not launch, neither from dock nor apps.
    What else can we do?
    TX
    Fred Vanderpoel
  • David Roth weiss
    November 8, 2008 at 6:21 pm
    [Fred Vanderpoel] “What else can we do?”
    That’s not sounding good Fred. You may probably be in for a reinstall. Here’s what I’d do…
    1) Backup all of your FCP project files to a safe drive, CD, thumb drive, etc., just so they are never in any jeopardy for any reason. Of course, you do that regularly anyway, right?
    2) Get FCS Remover at https://www.digitalrebellion.com/fcs_remover.htm and run it.
    3) Trash Preferences again.
    4) Repair permissions again.
    5) Run Disk Warrior again.
    6) Reinstall FCS2.
    7) Run Apple Software Update over and over again until you get the message your software is up to date.
    Hope this helps.
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
