Activity Forums Apple Final Cut Pro Legacy FCP 6 problems with re-capture
  • FCP 6 problems with re-capture
    Posted by Benjamin Bernard on June 15, 2007 at 1:41 am
    hey guys i dont know if anyone else has had this problem but I am getting offline sequences to be re-captured in a hi-rez codec for compositing but for what ever reason FCP is asking for the original whole clip which is about 40 gigs when the clips in the sequences are a max of 4 or 5 seconds if anyone had any ideas that would be awesome cause im out of them haha thank you
    Dan Riley replied 19 years, 2 months ago 4 Members · 5 Replies
  • Dan Riley
    June 15, 2007 at 2:10 am
    I know the link below is for FCP 4.5, but that doesn’t matter.
    Do what this link tells you and will have no problem uprezzing.
    https://www.kenstone.net/fcp_homepage/basic_onlining_jordan.html
    dr
  • Mark Raudonis
    June 15, 2007 at 4:46 am
    Dan,
    Thanks for the reference, but I’m experiencing the exact same problems and it seems to relate to FCP 6. We have a sequence started in 5.12, then media managed. Results are perfect. Take that same sequence, bring it into 6.0 and suddenly, a major percentage of the clips are not “Shedding” the unused media. No change to MM settings. Something is definitely going on here.
    mark
  • Dan Riley
    June 15, 2007 at 6:13 am
    I don’t have FCP6 yet so I can’t test it.
    You may be correct that something isn’t right.
    But in all previous versions since 4.0, the above suggestions worked.
    Dan
  • John Ryan
    June 15, 2007 at 6:51 am
    I am seeing the same thing. From A FCP 6 project emailed and burned on CD to my FCP 6 I am not able to digitize just the clips not matter what I do even though FCP knows the correct TC I have to type in TC by hand.
    It’s a bug alright, son of a bitch.
    John
  • Dan Riley
    June 15, 2007 at 3:02 pm
    Wow, this is a pretty big bug, mistake, tragedy… whatever you want to call it.
    Final Cut, what is it now….PRO ?
    No upgrade for me until this is figured out. All my shows go from DV roughcut to
    uncompressed SD Digibeta finishing.
    Dan
