Activity Forums Apple Final Cut Pro Legacy [FCP 6 o 7] File .MTS renamed .TS
  • [FCP 6 o 7] File .MTS renamed .TS
    Posted by Duca Simone luchini on June 15, 2010 at 8:36 am
    Hallo guys,
    I had many problems to see .MTS files (from Panasonic 151) and also the Panasonic dedicated Player (AvcCamviewer) was really disappointing…
    Now I’ve tried to rename these files from .MTS in .TS and i can finally see them conformable and good with VLC!
    Nevertheless I Don’t know if this new name extension (.TS) changes something about these files: in FCP (6 or 7) have I to capture like .MTS or I can simply import in FCP and drop in time line?
    In sum, can I utilize .TS file (renanmed from .MTS AVCCAM files) directly in FCP (By Import or Capture?) or I can only rename these .MTS files in .TS just for visualize in VLC?
    THX!!
    Jeremy Garchow replied 16 years, 2 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    June 15, 2010 at 2:29 pm
    You should leave them as MTS files and use log and transfer.
