Activity › Forums › Apple Final Cut Pro Legacy › FCP 6 in older G5
FCP 6 in older G5
Posted by Scott Sudbury on June 16, 2010 at 5:33 amI would like to run fcp 6 with my G5 with duel 2.0 GHz Power PC and 3.5 Gigs of ram.
Is anyone else using a similar set up and if so what are your thoughts?Scott Sudbury replied 16 years, 2 months ago 4 Members · 4 Replies -
Rafael Amador
June 16, 2010 at 10:59 amNo problem Scott.
I have my old (2004) G5 working with leopard and FC 6.0.5
rafael -
Jean-christophe Boulay
June 16, 2010 at 2:01 pmEverything should work fine. I have two such setups here that run very smoothly. Even working with SD uncompressed is very smooth. It start coughing a bit with some HD codecs, but it’s still workable.
Just keep in mind it is now an unsupported machine, so don’t go asking Apple Tech Support for help. Ask us instead.
JC Boulay
Technical Director
Audio Z
Montreal, Canada
http://www.audioz.com -
Jeremy Garchow
June 16, 2010 at 2:42 pmAnd Technically, you shouldn’t be able to capture HD ProRes.
