Activity Forums Apple Final Cut Pro Legacy FCP 6 format question
  • FCP 6 format question
    Posted by Nancy Yachnes on October 19, 2008 at 10:08 pm
    I have a job (tomorrow a.m, of course!)where the client is requiring 16:9 progressive. I am shooting with Sony Z7.
    If I shoot in SD after all, what should my AV and sequence settings in FCP be?
    Continued thanks,
    Nancy
    Don Greening replied 17 years, 11 months ago 2 Members · 1 Reply
  • Don Greening
    October 20, 2008 at 4:57 pm
    [Nancy Yachnes] “If I shoot in SD after all, what should my AV and sequence settings in FCP be?”
    The following recommendations apply if you live in NTSC Land. If you live in a PAL country then use the PAL versions:
    DV NTSC 48K Anamorphic. If your project will end up with lots of graphics, then a higher quality codec such as DVCPRO 50 48K Anamorphic or Pro Rez would suit you better. The higher quality codecs won’t make your SD video look any better but the graphics will benefit.
    – Don
