Activity Forums Apple Final Cut Pro Legacy fcp 6 distortion & pixelation issues
  • fcp 6 distortion & pixelation issues
    Posted by Patricia Defatta on September 8, 2012 at 10:57 pm
    Hi Creative Cow Community,
    Hopeful this forum can help me with a major fcp 6 issue. I am currently experiencing pixelation and distortion when rendering my timeline. I have made no changes to settings, etc. I started a new project, timeline, etc. but no change problem still occurring. I even trashed my preferences and reinstalled fcp 6 software but no change, pixelation and distortion still appearing. Oddly when I play previous projects that have been rendered, they play fine.
    It doesn’t matter if its video or jpeg images, when rendering I get the color pinwheel and the rendering is very slow. I am working on Mac G5 Power PC, 2.5GB memory, 16GB ram. I do not have other programs running in the background, so what could be causing this problem and how can I correct it?
    Greatly appreciate any suggestions since I am not sure what to do next.
    Thanks all!
    Patricia Defatta replied 13 years, 12 months ago 2 Members · 13 Replies
  • 13 Replies
  • Rafael Amador
    September 9, 2012 at 3:21 am
    What kind of footage?
    Which sequence settings?
    rafael
    http://www.nagavideo.com
  • Patricia Defatta
    September 9, 2012 at 1:18 pm
    the footage is from dvcam (it plays back fine and I pulled it from an older project which plays fine) so I don’t believe its the video.
    still images are jpeg’s but I also converted / sized them in photoshop.
    I have trashed all render files, but still getting pixelation, any other suggestions is greatly appreciated.
    thanks!
  • Rafael Amador
    September 9, 2012 at 2:42 pm
    DV is horrible for rendering.
    Change the sequence codec for Prores.
    rafael
  • Patricia Defatta
    September 9, 2012 at 3:26 pm
    Hi Rafael,
    Just did that and restarted but no change, still pixelation. Oddly my old projects play fine. Could this be a hardware issue? If so, what?
  • Rafael Amador
    September 9, 2012 at 3:49 pm
    i don’t think is nothing related with the hardware. With hardware issues, things go or don’t go, but normally do not make funny things on rendering.
    can you post a shot of your sequence settings, and the Video processing window?
    rafael
  • Patricia Defatta
    September 9, 2012 at 4:10 pm
    Ok Rafael, here’s what I’ve got. Also here is a pic of what I am getting. thanks!
  • Rafael Amador
    September 10, 2012 at 3:13 am
    Hi Patricia,
    That’s not just pixelation, that a huge corruption.
    There is really something wrong going on there.
    Your sequence setting are correct.
    One more question; Are your JPEG RGB and no CMYK?
    Suggestion:
    Open a new sequence, set Prores as the sequence codec and “Render all YUV in High Precision”.
    then make some graphics like a solid color background and some titles on top, and export.
    See what happens.
    rafael
  • Patricia Defatta
    September 10, 2012 at 3:31 am
    Hi Rafael,
    Thanks for hanging in here with me regarding this issue.
    The Jpegs are RGB
    Just tried your suggestion and got the same results. Not sure what to do next? Is this even fixable?
  • Rafael Amador
    September 10, 2012 at 4:14 am
    Patricia,
    There is something rotten in the rendering pipeline. If you would be having problems when displaying other things, i would say that could be a problem with your graphic card, but is not the case.
    Neither I can suggest you to re-install or trashing preffs because you have already done it.
    Two more suggestions:
    – Go to the Final Cut Render Folder and delete the “Constant Frames”.
    – Reapair permissions.
    rafael
  • Patricia Defatta
    September 10, 2012 at 12:36 pm
    Hi Rafael,
    I think you might have struck gold! I trashed the constant frames and did a quick sequence and no pixelations. Couldn’t spend too much time on it this morning, so hopefully this is the real fix, had to run off to work (as an Avid Editor). I will work with it later this evening. I will keep you posted.
    I can’t THANK YOU enough for ALL your help with this issue.
