Activity Forums Apple Final Cut Pro Legacy FCP 5.5 Tape error on capture
  • FCP 5.5 Tape error on capture
    Posted by Jim Froom on July 20, 2006 at 1:19 am
    I also posted this in the AJA Kona forum.
    Tape Trouble, Check VTR. Running FCP 5.1. With Kona LHe in G5 Quad with 2.5 gb ram.
    Drives are running over 225 on reads and writes. Internal drive runs around 45 or so. All scratch disks are set to the 225+ drives.
    DV captures fine from camera.
    I can’t capture from DVC pro deck with DV tape via component for more than 25 seconds to 3 minutes to the Kona LHe card. Get the Tape Trouble, Check VTR from FCP.
    Deck works fine with other editing machines. Time code isn’t broken. IT just stops and thinks it’s at the end of the tape or something. No reports of drop frames.
    Have tried ignoring dropped frames and that doesn’t help. Have run it and the deck with and without house sync.
    Also running ATTO SCSI 5d card.
    Help….. Help….. Help….
    Matt Jennings replied 16 years, 11 months ago 2 Members · 2 Replies
  • Jim Froom
    July 20, 2006 at 12:28 pm
    Problem solved. AJA sent me a plug in for FCP for reducing polling and it worked. It was called DiableAltETTPolling.txt
  • Matt Jennings
    October 2, 2009 at 5:55 pm
    take a look here – its to do with device polling intervals
    https://support.apple.com/kb/HT1942
    Worked great for me!
