Activity Forums Apple Final Cut Pro Legacy FCP 5.2 Update. Where is it?
  • FCP 5.2 Update. Where is it?
    Posted by Tom Matthies on September 27, 2006 at 1:33 pm
    Watching the posts about the 5.2 update. If I go to software update, FCP isn’t showing up for some reason. I’m getting a bunch of other updates related to it but FCP but not Final Cut itself. Hmmm?
    tom
    Paul Nevison replied 20 years ago 5 Members · 6 Replies
  • Daniel Elder
    September 27, 2006 at 1:40 pm
    go to apple support, then to software, then to final cut pro, and the update will be on the side bar.
    Once there you will need to have your apple id and serial number handy. And then you can download
    Daniel Elder
    Associate Producer
    http://www.luminair.com
  • Peter Wiggins
    September 27, 2006 at 2:11 pm
    There isn’t a 5.2 update! its 5.1.2
    Also have you done the crossgrade etc? If you have an older copy of FCP, say 5.0
    then the upgrade might not work
    Peter
    Free Motion Templates
    peterwiggins.com
  • Walter Biscardi
    September 27, 2006 at 2:12 pm
    [Peter Wiggins] “If you have an older copy of FCP, say 5.0
    then the upgrade might not work”
    It won’t work period. You must have FCP 5.1 installed for this update to work. 5.0.4 was the last update for FCP 5.0.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Peter Wiggins
    September 27, 2006 at 2:52 pm
    Walter,
    Well I was initially going to say “If you haven’t got 5.1 you are s****d”
    but I thought I’d be a bit more subtle 🙂
    Peter
    peterwiggins.com
  • Tom Matthies
    September 27, 2006 at 2:58 pm
    I’m running 5.1 crossgrade right now. It’s registered with Apple. I just went to Software update under the Apple menu. I’m actually in the middle of a project right now(several actually) so I was just looking to see if the update was available. I’m not going to do the upgrade until I finish up what I’m currently working on. I also have the software for the crossgrade for my home system (just got it this week) but haven’t had time to do it yet.
    I’m more curious than anything. Just wondering why it wasn’t showing up under the software update pulldown.
    tom
  • Paul Nevison
    September 27, 2006 at 3:19 pm
    check you are running QT 7.1.3….if you dont have that installed the update won’t show as it is a requirement. I’m holding tight till i get the go ahead from capture card provider BMD.
    G5 DP 2.0 (Power PC)
    4.0G RAM
    OS 10.4.7
    QT 7.1.2
    FCP 5.1.1
    BMD Decklink Extreme 5.6.2
    PAL Land
