Activity › Forums › Panasonic Cameras › FCP 5.1.3 now available
Shane Ross
February 18, 2007 at 7:05 amTroubleshooting is occurring as we speak. I have at Dual 2Ghz G5, and the same error occurs on that and my Powerbook AND my producer’s MacBook Pro. So…not that.
But, we are looking into the camera firmware versions…
Shane
Littlefrog Post
http://www.lfhd.net -
Mitch Ives
February 18, 2007 at 5:05 pmI agree, since I also have a G5 Dual 2.0, PowerBook G4, and new C2D MBP, and have not seen that. Did you want to post your firmware versions? If you want I can check mine and post them on our two HVX’s…
Mitch Ives
Insight Productions Corp.
mitch@insightproductions.comApple Certified Trainer: Final Cut Pro 5
Mitch Ives
February 21, 2007 at 8:51 pm[Shane Ross] “I see all 10 in the Import window. Then I highlight them all and put them in the IMPORT QUE and they begin to import. Then I get exclaimation points next to 6 of them, indicating an error importing. IN the import window, 4 clips have the circle to the left of them darkened, indicating they have imported properly. I go to the capture scratch folder and see that yes, only those 4 clips have been imported.”
Shane, yesterday I had something similar occur, but it’s still different than yours. Only 28 of the 29 clips would show up in the P2 Import window. Nothing I did would make the last one (the first clip actually) appear. It was on the P2 Store, but no joy. I finally put the card back in the camera and it was white with the red X on it. It worked perfectly before, but now it was damaged.
So I repaired the clip in the camera and got it playing in the camera. I then erased the P2 Store HD and then re-transferred the entire folder and last clip file again. Now, all 29 show up and import as usual.
The camera in question was really old firmware… 1.03. Last night I updated to 2.03 on both cameras, so I’ll track to see if it happens again.
Mitch Ives
Shane Ross
February 21, 2007 at 10:05 pm[Mitch Ives] “1.03. Last night I updated to 2.03 on both cameras, so I’ll track to see if it happens again.”
How did you update? I want to get my camera crew on this tonight.
Shane
Littlefrog Post
http://www.lfhd.net
