Activity Forums Panasonic Cameras FCP 5.12 does not import variable frame rate clips
  • FCP 5.12 does not import variable frame rate clips
    Posted by Arthur Aldrich on September 29, 2006 at 10:37 am
    I shot some clips on p2 cards in 720p24PN at variable frame rates.
    FCP 5.12 will see the clips in the new p2 import screen, but will not play them, and when I import, the clips show up as white frames.
    Anyone else seeing this?
    I am working on MacPro 3Ghz with 5GB ram.
    Art Aldrich
    Leader, NJ FCP UG
    http://www.njfcpug.org
    Gary Adcock replied 19 years, 11 months ago 5 Members · 8 Replies
  • 8 Replies
  • Noah Kadner
    September 29, 2006 at 2:26 pm
    Hi Art-
    Hmm- I have under and overcranked 720p 24pn clips here that play perfectly in the importer and then after import too in 5.12 on my MacBook Pro. Is that directly from a card or on a HD or a P2 store or a Firestore? Mine are copied from P2 to a hard drive. Maybe try a trashing of the prefs?
    Noah
  • Arthur Aldrich
    September 29, 2006 at 2:35 pm
    These were from a P2 Store, and I also tried from p2 files copied from HD.
    I trashed the prefs, but no love.
    I will try it on my MacBookPro and see if it works there.
    Art Aldrich
    Leader, NJ FCP UG
  • Jeremy Garchow
    September 29, 2006 at 3:28 pm
    [Arthur Aldrich] “the clips show up as white frames.”
    This usually means you don’t have the DVCPRO HD codec installed on your machine, but that should have installed when you installed FCP.
    Do me a favor and look in your HardDrive > Library > Quicktime folder.
    Do you see a file named: “DVCPROHDCodec.component” ?
    Jeremy
  • David S.
    September 29, 2006 at 4:15 pm
    Working fine here.
    720/24pn 60
  • Gary Adcock
    September 29, 2006 at 4:24 pm
    Hey Art
    I have not had an issue in 5.1.2 with the P2 import of VFR material recorded in “24p” mode
    nor am I having an issue with Varicam footage and the FRC. (via 1400 deck) (@ the varicamp in LA)
    let me know if I can help.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Gary Adcock
    September 29, 2006 at 4:42 pm
    Art
    One other thing – is there any other hardware in your desktop?
    have you run the Firmware update?
    try with 2 gigs of RAM – there are some issues with 3rd party hardware in the MacPro not being able to function with the RAM
    gary adcock
    Studio37
  • Arthur Aldrich
    October 2, 2006 at 10:17 am
    I decided to import the clips on my MacBook Pro with FCP 5.1.2, and it worked fine.
    I then hooked up the hvx via firewire to the MacPro, and it worked fine. I also tried it again from the p2 files on my hard drive, and this time it worked fine.
    Strange…
    Art Aldrich
    Leader, NJ FCP UG
  • Gary Adcock
    October 3, 2006 at 1:29 pm
    [Arthur Aldrich] “I then hooked up the hvx via firewire to the MacPro, and it worked fine. I also tried it again from the p2 files on my hard drive, and this time it worked fine.”
    Art
    I have found out that if you set in /out points on P2 materials with FCP 5.1.2 while the content is still on the cards, you get intermittent results with the imported materials- #1 of which was an inability to process the 720p offspeed/60 P2 clips thru the Software FRC.
    The data would import on the first machine i tested it on, but the cloned and copied versions of the same P2 card would not allow the material to pass thru the FRC after master version was imported the first time in FCP.
    It “looked” as if FCP modified the material on the card and it was no longer compliant on the cloned versions, However I was not able to see what or where the card data had been touched by FCP, yet it was how the materials responded when I tried to run the files thru the FRC.
    There was NOT a problem importing the data from the cards that was fine, only how the FRC handled (or did not)the content when converting the frame rates.
    still testing to find out if it was operator error or something else.
    gary
    gary adcock
    Studio37
