Activity › Forums › AJA Video Systems › FCP 5.1.2 – 1080/24PsF – Rendering of wrong frame?
  • FCP 5.1.2 – 1080/24PsF – Rendering of wrong frame?
    Posted by Ben Cheng on November 21, 2006 at 12:07 pm
    Hi All,
    I like to seek your advice on this issue.
    << Problem >>
    Working in 1080/24PsF Uncompressed 8bit, rendering will cause FCP to render from media 5 frames before the actual media.
    This affects all types of render, text overlay, mask or video effects.
    e.g In Point is 00:10:00:00 and Out Point is 00:10:10:00.
    The rendered media will start at 00:09:59:19 and end at 00:10:09:19.
    When playing back the rendered clip, it look like there’s a jump in motion, as the rendered clip is not the correct media.
    << System Configuration >>
    2 PowerMac G5 and there are different models
    2GB RAM
    AJA Kona 2
    Mac OS X 10.4.8
    QuickTime 7.1.3
    FCP 5.1.2
    Kona 3.2 driver
    1 system has Apple XServe RAID + Apple FC card
    1 system has Huge U320RX-2500 + ATTO UL5D
    This issue seems to be FCP related, not hardware.
    As this is happening on both FCP systems, each with different storage system.
    We tried re-creating a new project/sequence and trashing the FCP preference files.
    For other HD formats, so far everything is fine.
    Wonder if you have any advice or any experience with such an issue?
    Any kind of suggestion or advice is greatly appreciated.
    Hope to hear from you soon. Thanks again!
    Cheers,
    Ben Cheng
    Application Engineer
    The Media Village Pte Ltd
    David Battistella replied 19 years, 10 months ago 2 Members · 1 Reply
  • David Battistella
    November 21, 2006 at 3:04 pm
    Yes.
    I can confirm. I have been having similar problems when using MM to transcode media to this codec. It all comes out looking progressive and with field issues.
    David
    Peace and Love 🙂
