Activity › Forums › Apple Final Cut Pro Legacy › FCP 5.1.1 won’t let me log and capture
  • Jerry Hofmann
    June 13, 2006 at 4:18 pm
    QT 7 installs can cause this… check out: https://docs.info.apple.com/article.html?artnum=301852
    Might try a different cable… if you didn’t do a clean install of Tiger, that too could be part of the problem.
    Jerry
  • Keith Golinski
    June 13, 2006 at 7:22 pm
    Thanks Jerry I’ll give it a try. There’s always something to every upgrade isn’t there?
    Thanks for your time.
    Keith Golinski
    FULVEW
  • Keith Golinski
    June 14, 2006 at 2:54 pm
    Jerry It worked…dropping the old quicktime receipts was the trick. Thanks again for sharing your wisdom.
    Keith Golinksi
    FULVEW Productions
