Activity › Forums › Apple Final Cut Pro Legacy › FCP 5.1 Out of Sync DV50 footage
  • FCP 5.1 Out of Sync DV50 footage
    Posted by Don Forschmitt on January 23, 2007 at 2:26 am
    Just upgraded to 5.1 and most working well. Came across a strange situation when working with DV50 footage. It’s working fine bringing in Beta through AJA and DV through Firewire and working in a DV sequence.
    Just brought in some DVCpro50 footage through firewire at DV50 capture setting. And when I make a DV50 sequence and drop in any footage, it needs to be rendered (which it shouldn’t) and when I render it, it’s out of sync. To get around it for now, I create a DV sequence, drop in the footage and after rendering it plays fine in sync.
    I opened the digitized quicktime movies and they play fine in QT player.
    Is it a setting I am missing? BTW, the footage is out of sync by about a second. Very strange.
    Any thoughts. Thanks.
    FCP 4.5 HD
    Dual 2gig G5
    2 gig RAM
    2 internal drives 160GB/250GB
    G-RAID 500 GB
    G-Drive 160 GB
    UVW-1800
    DSR-11
    AJA IO la
    http://www.primelight.net
    Bret Williams replied 19 years, 8 months ago 4 Members · 4 Replies
  • Steve Eisen
    January 23, 2007 at 2:30 am
    I do not see a DVCPro 50 deck in your profile. That may be your problem.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Don Forschmitt
    January 23, 2007 at 2:55 am
    Old list. I now have a Panasonic AJ-SD93. I have been bringing in DV50 with this deck on FCP 4.5 with no problems.
  • Jeremy Garchow
    January 23, 2007 at 3:35 am
    [Don Forschmidt] “nd when I make a DV50 sequence and drop in any footage, it needs to be rendered (which it shouldn’t) and when I render it, it’s out of sync.”
    you have something set wrong somewhere. Are you sure the footage is DV50? Are oyu sure dv50 is coming out of the firewire and not dv?
    Control-q > Choose dv50 NTSC easy setup (not dv50 23.98), make new sequence, capture and away you go.
    Jeremy
  • Bret Williams
    January 23, 2007 at 6:59 am
    Oddly enough, I’m working with DVCPro50 in a DV50 setup and some clips most certianly drift out of sync or are simply out of sync from the beginning. No need to render any clips however.
    Running 5.x on Dual G5.
