Activity Forums Apple Final Cut Pro Legacy FCP 5.1 ‘Out of Memory’ Message, Trying to do MultiCam Edit
  • FCP 5.1 ‘Out of Memory’ Message, Trying to do MultiCam Edit
    Posted by John Schlue on December 5, 2008 at 5:47 am
    I just began trying to edit a project using the Multi-Cam Edit feature on FCP 5.1. When I try to open my multiclip in the viewer I’m getting “general error” followed by “out of memory” messages.
    I’ve tried playing with the scratch disk, cleared my hard-drive of excess crap… No luck.
    *Its worth noting: in my situation I didn’t do a standard capture, I imported 5 quicktime files that were shot using flip video cams. Could this be my issue?
    Any suggestions?
    JSloo
    John Schlue replied 17 years, 8 months ago 6 Members · 6 Replies
  • Paul Dickin
    December 5, 2008 at 10:13 am
    Hi
    In my experience a General Error most often results from using clips that don’t have a proper FCP-acceptable frame rate, or have frames that intermittently vary in length.
    Either use QuickTime Player to Export new movies with a correct fps rate, or use Cinema Tools to Conform your existing clips to their proper frame rate.
  • Ben Holmes
    December 5, 2008 at 10:38 am
    Often this issue can only be fixed by reverting to a previous auto-save. You’ll find numerous threads here about this if you search.
    Trashing render files manually might do it – but often it seems to be a corruption in the project file.
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
  • Jerry Hofmann
    December 5, 2008 at 12:03 pm
    Post the format that these cameras shoot, I’m thinking much like Paul… bet it’s not directly supported by FCP… and transcoding it all will clear this up.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Mark Raudonis
    December 5, 2008 at 3:03 pm
    You’re using 5.1
    Apple has made many, many improvements specifically in Multi-cam performance since then.
    The best thing you can do is upgrade to the current level. Until then, you’re going to be struggling with issues that have already been addressed. Do yourself a favor… upgrade now.
    mark
  • Michael Pearce
    December 26, 2008 at 5:12 pm
    I have a couple of issues –
    I have 15 cameras on a concert, that is 1 hour 40 mins and have grouped together the first batch,
    however when trying to create the next multiclip, I get a message ‘Couldn’t create the clip
    because exceeds maximum duration of 12 hours (or 6 hrs for sequences with high audio rates)
    the only difference with this grouping is that some are sub clips due to tape changes or recording stops.
    I hope this is a setting somewhere, which I can’t find, otherwise kind of defeats the multiclip purpose?
    Next problem is that I can’t edit with the 15 cameras as the viewer stops after a few seconds,
    I am guessing this may be a RAM/processor problem…seems ok with 7 or 8 cameras though.
    Thanks for any advice.
    Michael Pearce
    Imac
    Intel Core 2 duo
    4 GB Ram
    external drive
    G Tech 1 TB
    250 GB free
  • John Schlue
    December 26, 2008 at 6:08 pm
    I can’t offer any advice on your first problem but for the issue of playback with 15 cameras…. have you tried changing the RT settings to help ease the playback congestion? You may have done this already but if not, just left to the sequence playhead is the RT tab: you might find that you are able to run all 15 by changing the settings to
    unlimited
    play base layer only
    PVQ: low
    PFR: low
    multiclip playback
    *note: make sure you also have record to tape set to full quality or upon final edits switch settings back to dynamic before exporting or converting.
    sorry if this doesn’t help or you’ve already taken these steps!
    Good Luck
