Activity Forums Apple Final Cut Pro Legacy FCP 5.1 Bugs?
  • Posted by Marshall Lee on September 29, 2006 at 10:47 pm
    Running off a G5 Dual 2.3 on OS X 10.4.7. Final Cut 5.1.
    I am trying to finish a documentary that was done on a iMac G5 on FCP 5.1. The project came to me on a G Tech 500 gig drive. So i duplicated the sequence so I could work off my own sequence and upon working, found that there were certain clips that were embedded into other clips. Usually clips that had titles over top. This kept happening every so often on 90 minutes of the sequence. Trying to get a quick fix, i figured out that if I moved the clip to a different video track and rendered out, the mysterious embedded clip would go away.
    Should I be updating to FCP 5.1.2? or should I wait till this project is done?
    Any help would be great! Thanks so much
    Marshall
    Marshall Lee replied 19 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
