Activity Forums AJA Video Systems FCP 5.1 and 6 on same system with Kona 3
  • FCP 5.1 and 6 on same system with Kona 3
    Posted by Chris Lundy on September 14, 2007 at 1:06 pm
    If one needed both versions on their systems what might be the best way to do it while maintaining the correct Kona 3 drivers?
    I’ve read adding an additional internal drive to install OSX and FCP6 makes for a less buggy system. This seems the best way to keep the requisite Kona drivers separate as well.
    But what if I attempted both FCP versions on the same system drive? Is there a way to get both Kona drivers on there and have them function correctly?
    Thoughts?
    Chris Lundy
    PostWorks New York
    Jeremy Garchow replied 18 years, 11 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    September 14, 2007 at 4:36 pm
    Keep it separate, it what I do. I have two boot drives, one for FCP5 and one for FCP6 with the different drivers (v3 & v4) on those different boot drives.
    Keep your life simple and don’t try and mix and match. To choose a different boot drive, simply restart and hold option, a pop up will come up and you arrow to your boot drive and press return.
    Jeremy
