Activity Forums Apple Final Cut Pro Legacy FCP 5.04 Capture window
  • FCP 5.04 Capture window
    Posted by David Peled on October 5, 2010 at 2:56 pm
    It takes more then a minute to the Edit to Tape or Capture windows to appear and be ready for action.
    I cleared all kind of cache files I know of, replaced preferences files, switched users, re install the BlackMagic driver, with no luck at all. After the window is up and ready, I can continue as normal.
    What else can be done here?
    David Peled.
    Rafael Amador replied 15 years, 11 months ago 2 Members · 3 Replies
  • Rafael Amador
    October 5, 2010 at 3:51 pm
    Run DiskWarrior.
    Rafael
    http://www.nagavideo.com
  • David Peled
    October 5, 2010 at 4:12 pm
    Thanks.
    The capture media is a Gdrive Raid with 4 Sata drives.
    There’s nothing wrong with the file system on it.
    It was checked with diskwarrior.
  • Rafael Amador
    October 5, 2010 at 4:15 pm
    [David Peled] “The capture media is a Gdrive Raid with 4 Sata drives.
    There’s nothing wrong with the file system on it. It was checked with diskwarrio”
    Run it in your System HD, that is the important one.
    rafael
