Activity › Forums › Apple Final Cut Pro Legacy › FCP 5.0 can it output 4 channels of audio?
  • FCP 5.0 can it output 4 channels of audio?
    Posted by Matt Bishop on July 21, 2005 at 2:41 pm
    Hello, I was wondering if anyone had any advice on a 4-channel audio output solution. Here is what I was thinking, and I was curious if this is possible…In FCP 5.0 if I use a Decklink Extreme Card can I output 4 channels of audio via SDI to a Digital Betacam (DVW-500) in a single pass, or do I have to do this in two passes?
    If anyone has any advice it would be greatly apprechiated, thanks.
    Cheers
    Matt
    Matt Bishop replied 21 years, 2 months ago 5 Members · 5 Replies
  • Jerry Hofmann
    July 21, 2005 at 2:54 pm
    If you have the hardware… it can output up to 24 channels…
    Jerry
  • Walter Biscardi
    July 21, 2005 at 3:22 pm
    [Matt] “In FCP 5.0 if I use a Decklink Extreme Card can I output 4 channels of audio via SDI to a Digital Betacam (DVW-500) in a single pass, or do I have to do this in two passes?”
    Simply go into your Sequence Settings > Audio Output. Change it to 4 channels and whether you want the channels to be dual mono or stereo. Then go into your timeline and assign your audio tracks as needed.
    I do this all the time now with Kona 2. FCP 5.0 can now capture 8 channels of audio as well with the right hardware.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Alexander Serpico
    July 21, 2005 at 3:32 pm
    Now FCP 5 can load 4 channels of audio.
  • Tom Wolsky
    July 21, 2005 at 5:22 pm
    You could do this in v4.
  • Matt Bishop
    July 21, 2005 at 6:42 pm
    Many thanks to everyone for their advice.
    Cheers
    Matt
