Activity Forums Blackmagic Design FCP 5 w/Extreme Edit To Tape???
  • FCP 5 w/Extreme Edit To Tape???
    Posted by David Roth weiss on August 22, 2005 at 5:04 am
    I’m trying to Edit To Tape for the first time and not having much luck. I keep getting the following error message:
    Incompatible Compression Settings.
    You may have attempted to output a clip with
    compression settings that do not match the current
    output settings. Try nesting the clip in a sequence with
    the correct settings.
    Here’s where I’m at… I setup the Project using Easy Setup as BM NTSC JPEG and I captured and edited everything just fine. Playback through the Extreme card was automatically set to BM NTSC 8-Bit and all is fine there, everything on the timeline displays very well on my NTSC monitor via the BM component output, and the component signal is then routed from the monitor to my UVW-1800. BTW, I also tried nesting the sequence in new sequence with the correct settings as suggested by the error message, and I rendered the whole thing too, but no dice…
    So, what’s the problem? Is there something I’m missing? Any help would be greatly appreciated.
    TIA,
    DRW
    (FCP 5.02 — Latest BM drivers — UVW-1800)
    Luke Maslen replied 21 years, 1 month ago 4 Members · 8 Replies
  • 8 Replies
  • Smoked Meat
    August 22, 2005 at 5:36 am
    Coincidentally, I encountered the same error message – just earlier today. Unlike you, I was working in BM 10-bit uncompressed NTSC. As a temporary workaround, I exported a Quicktime reference movie,k dropped it into Blackmagic Deck Control, and put it to tape from there,
    But I really wish FCP’s Edit to tape worked – I really need to do a few precise inserts within the completed output…
  • David Roth weiss
    August 22, 2005 at 5:51 am
    Dear Mr. Meat,
    So, your thought is that it doesn’t actually work as its supposed to? Or, do you think we’re both missing something?
    DRW
  • Smoked Meat
    August 22, 2005 at 6:03 am
    Mr. DRW,
    Yes and possibly yes. I find it extremely odd, but I’ve been on FCP 4.5 until very recently so I can’t say for sure. Another oddity is that yesterday I couldn’t drag and drop any kind of FCP sequence or clip into the Edit to Tape window. But as I say, I’m just getting up on FCP5. Others on this board are likely to be far more capable with this question that I.
    Mr. Meat
  • Kristian Lam
    August 22, 2005 at 7:31 am
    Hi David,
    When getting the error message, what do you have in your Viewer window?
    Have you tried dragging the Sequence from the Browser window onto the “Insert” / “Assemble” icon in the Edit To Tape window?
    regards
    Kristian
    Blackmagic Design
  • Luke Maslen
    August 22, 2005 at 7:57 am
    Hi David,
    The solution to your problem is contained in the support note Incompatible compression settings error message in Final Cut Pro during Edit to Tape.
    Please let me know if this helps or if you still encounter problems.
    Regards,
    Luke Maslen
    Blackmagic Design
  • David Roth weiss
    August 22, 2005 at 8:14 am
    BINGO!!! Thanks Kristian, I was going completely bonkers trying to get this to work… For some unknown reason I could not find it in the manual though I searched long and hard.
    THNX,
    DRW
  • David Roth weiss
    August 22, 2005 at 8:23 am
    Okay Luke, this is absolutely the last time you’re gonna have to bail me out. I hope… Hey, it not only works, but seems to be quite elegant. Now I’m really cooking.
    You guys are great and so on the ball…
    THNX,
    DRW
  • Luke Maslen
    August 23, 2005 at 2:21 am
    Hi David,
    You’re most welcome and I’m glad this has got you going. That particular error message kept appearing in this forum some while ago so I asked Apple about it and they were very helpful in supplying information. We created the support note as it is a tricky problem to solve but easy once you know how. Thanks for your kind words 🙂
    Regards,
    Luke Maslen
    Blackmagic Design
