Activity Forums Apple Final Cut Pro Legacy FCP 5 turning my jpegs and png’s green
  • FCP 5 turning my jpegs and png’s green
    Posted by Paul Nevison on November 7, 2005 at 8:08 pm
    hey there,
    working on a seq with lots of stills which i have added filters to and am tilting on their axis. when the playhead is stoped over the unrendered footage it looks right as soon as i render the stills are replaced by a solid green block where the still image should be. the stills are jpegs and same thing happened when i converted them to png’s
    any ideas?
    G5 DP 2.0
    2.0G RAM
    OS 10.4.2
    QT 7.0.3
    FCP 5.0.3
    BMD Decklink Extreme
    Martti Ekstrand replied 20 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Paul Nevison
    November 7, 2005 at 8:14 pm
    tracked down the problem to a third party filter i was using to desaturate the image. any idea why this filter would have this kind of effect? is there some fxscript reason that some plugins conflict and other dont etc…?
    i’m curious
    G5 DP 2.0
    2.0G RAM
    OS 10.4.2
    QT 7.0.3
    FCP 5.0.3
  • Kevin Monahan
    November 7, 2005 at 9:52 pm
    Which filter was it?
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Paul Nevison
    November 7, 2005 at 10:00 pm
    black and white filter from “two much too soon” collection.
    G5 DP 2.0
    2.0G RAM
    OS 10.4.2
    QT 7.0.3
    FCP 5.0.3
  • Todd Beabout
    November 7, 2005 at 11:43 pm
    I’ve found that when FCP does this you can get around it in a pinch by turning off YUV rendering, especially if you are using 10-bit. A lot of the Sapphires (which I use often) will do this. You can ctrl-click the sequence, go to sequence settings, and then the render control tab I beleive. I’ve had to turn it to RGB for other reasons too (e.g. using motion blur in a variety of situations, like on top of composite modes, etc…) Hope this helps.
    -Todd Beabout
    Vazda Studios
  • Paul Nevison
    November 7, 2005 at 11:56 pm
    Thanks Todd,
    that would effect the quality of your final render especially in 10 bit – i always forget which is better RGB or YUV?
    G5 DP 2.0
    2.0G RAM
    OS 10.4.2
    QT 7.0.3
    FCP 5.0.3
  • Todd Beabout
    November 8, 2005 at 12:00 am
    Yes, it not only affects the render quality, but I have also noted at times shifts in the video/chroma levels. It is not ideal, but it will get you through in a pinch. YUV is the better quality BTW.
    It would be interesting to see if changing your render settings helped in your case though… Might help you/someone track down where the problem is.
    Good luck you you!
    -Todd Beabout
    Vazda Studios
  • Martti Ekstrand
    November 8, 2005 at 7:22 pm
    Unless you want to do fades from colour to B/W why don’t you desaturate the jpegs in Photoshop or such first? Should shorten render times a little as well.
