Activity Forums Apple Final Cut Pro Legacy FCP 5 rendering slower?
  • FCP 5 rendering slower?
    Posted by David Fortin on March 24, 2006 at 4:31 pm
    I purchased FCP5 a while back but didn’t upgrade because I never had a break in the projects. I finally got around to doing a clean install of OS 10.4.5 and FCP 5.0.4. I did the install on a new hard drive and followed people’s advice about installing from the disk then doing the updates from the web, and reparing permissions.
    I’m working on a project now and it seems to me that FCP is taking longer to render than it use to.. Could that be possible?
    I still have FCP4 on a different HD and operating system. I guess when I have some free time (ha, ha) I can do a comparison build on both systems.
    But I am curious to know if anyone else noticed the difference?
    David
    Dual 2.5 G5 {OS 10.4.5}
    4.5 GB RAM
    FCP 5.0.4
    NVIDIA GeForce 6800 Ultra DDL
    DeckLink SP
    ATTO ExpressPCI UL4S
    Medea Video Raid RT320
    Sony UVW-1800
    Pansonic AG-DV2500
    Media Cleaner Pro 6
    Squeeze 4.2 (PC)
    ViewSonic 19″ LCD
    Optiquest 21″ CRT
    Bella EZ Keyboard
    Morabs replied 20 years, 5 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    March 24, 2006 at 8:11 pm
    Actually, it does render a bit slower on any motion effects if you don’t change the stock settings in the sequence video processing tab. If you change that back to “fast” it’s the same quality and speed as FCP HD was. But if you use “normal” or “Best” the Motion renders will be slower, however of higher quality. Other than that, the speed should be pretty much the same.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Richard Feger
    March 27, 2006 at 2:43 pm
    Is FCP a true universal app? If yes, will running FCP version 5 on a PPC G5 have negative consequence on performance? Thanks
  • Morabs
    March 28, 2006 at 9:45 pm
    can you contact me at my email address i have some serious rendering issues that I think you can assist me with.
    morabs@mac.com
    818-235-7743
