Activity › Forums › Apple Final Cut Pro Legacy › FCP 5: None Responsive Broadcast Safe Filter
  • FCP 5: None Responsive Broadcast Safe Filter
    Posted by Legtheeditor on June 30, 2006 at 4:21 pm
    hello cow community, I’m currently using FCP 5 and I am printing episodes to tape for broadcast. before i print i nest my timeline and from that nest I reformat my 16×9 footage to fit the best it can in 4×3, at this time i also put the “Broadcast Safe” filter on my whole nest which in the past has worked perfectly to keep my show with in legal limits. Now the problem is that my once perfect Broadcast Safe filter is no longer working! I’m seeing it bring my levels down to legal through my scopes but once I render then once legal footage has bounced back out of legal! I’ve noticed that some of the clips in the nest have the same broadcast safe filter on them as well so there are filters on top of filters, i’ve played with removing those and working with just the nest filtered and/or just the clips filtered but still the filter is not keeping my footage legal. I hope i have made some sense as this problem is quite qwirky, hopefully someone out there has exprienced something like this and can shed some light on an approach.
    thanks for the time,
    Adam
    Dan Riley replied 20 years, 3 months ago 5 Members · 8 Replies
  • 8 Replies
  • Kevin Monahan
    June 30, 2006 at 5:33 pm
    I had some problems with various systems with the Limit Effects function of the Color Corrector, so my fix may apply to you: Trash Your Prefs.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Legtheeditor
    June 30, 2006 at 6:33 pm
    appreciate the reply Kevin, I’ve tried trashing the prefs already, no luck
    – Adam
  • Mark Maness
    June 30, 2006 at 8:37 pm
    I have seen all of these problems, too.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Legtheeditor
    June 30, 2006 at 9:22 pm
    well its nice to know im not the only one cursed, I’ve seen the broadcast filter do great things in the past though, however that was in 4.5…
    Adam Brostoff
    Editor
    Rogar Studios
    206 New Highway
    Amityville, NY 11701
    http://www.rogarstudios.com
  • Dan Riley
    June 30, 2006 at 9:44 pm
    I assume you have gone into the filter settings and set it for
    very conservative (luma tops at 100%, chroma at 110%)
    or extremely conservation (luma and chroma both to 100%) ?
    The other settings are not useful for broadcasting.
    Transmitters will clip any luminance at 100 and
    chroma at 110 (sometimes, depending on the
    proc amp settings). If you don’t do it on your end,
    they will. But it looks better if you do it.
    Dan
  • Legtheeditor
    June 30, 2006 at 9:56 pm
    yes i have done that and it hasn’t been working which is where this irregular problem comes in, it is important that i deliever my stuff already prepared for broadcast though because of contractual reasons.
    Adam Brostoff
    Editor
    Rogar Studios
    206 New Highway
  • David Roth weiss
    July 1, 2006 at 11:37 pm
    Adam,
    Why not use this as an opportunity to learn the Three Way Color Corrector? With it you can not only do what the Broadcast Safe Filter does, you can do it better.
    DRW
  • Dan Riley
    July 2, 2006 at 6:26 am
    The 3W CC does not have a clipper to lop off the luminance and
    chrominance at 100 or 110%. You can use the color corrector
    to lower levels and chroma overall, yes, and you should do that
    first, so you aren’t kicking the sh….t out of the top of the clipper.
    But they don’t do the same thing. And if all you want to do is
    lower the video level of a clip, you really should do that with the proc amp.
    Lowering the “whites” in the 3WCC is not the same as lowering
    the overall video level. It will change the shape of your gamma.
    Bottom line is, you should always color correct (including levels)
    every shot in your timeline BEFORE using the broadcast safe
    filter as a final protection anyway.
    Dan
