Activity › Forums › Apple Final Cut Pro Legacy › FCP 5 + Kona 2 + Panasonic AJ-SD93 VTR
  • FCP 5 + Kona 2 + Panasonic AJ-SD93 VTR
    Posted by Ben Cheng on November 25, 2005 at 5:29 am
    Hi
    I would like find out any users here using the following gear :
    May I know whats the FireWire + RS-422 capability & limitation of Panasonic AJ-SD93 VTR ?
    Tested Edit-to-Tape via RS-422 & unable to perform insert edit
    Assemble edit seems fine
    Hence using FireWire for remote now, however there’s an issue with timecode drift, during insert edit
    May I know whats the best way to setup remote control for AJ-SD93 VTR ?
    Cheers
    Ben Cheng
    The Media Village
    Ben Cheng replied 20 years, 10 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    November 25, 2005 at 3:35 pm
    You’ve blacked the tape for the insert or have video on either end of it right? If so I’d think that the RS-422 should work the best here, and you should set your device control setting to be the Kona Sony VTR A or B… you’ll need to check accuracy of the timecode to adjust the device control setting and determine how playback is accurate. This is best done with a window burn tape whose burn matches the TC on it’s TC track… The Kona Sony RS-422 sets the TC read to be LTC as it’s stock preset, but I’ve found better results to set that setting to be LTC+VITC with analog machines, might try that for the Panasonic too.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Ken Zukin
    November 27, 2005 at 4:02 am
    Did you order the analog card for your SD93(from Panasonic)? It’s about a thousand bucks, and I’m 99% sure you’ll need that to have RS422 deck control.
  • Ben Cheng
    November 28, 2005 at 11:40 am
    Hi guys
    Tks so much for your replies
    Ken : The VTR is equipped with the analog option
    Please take a look at this thread for more replies
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=98&postid=857172&threadid=857169&pview=t
    Cheers
    Ben
    The Media Village
    Singapore
