Activity › Forums › AJA Video Systems › FCP 5 + Kona 2 + Panasonic AJ-SD93 VTR
  • FCP 5 + Kona 2 + Panasonic AJ-SD93 VTR
    Posted by Ben Cheng on November 25, 2005 at 5:29 am
    Hi
    I would like find out any users here using the following gear :
    May I know whats the FireWire + RS-422 capability & limitation of Panasonic AJ-SD93 VTR ?
    Tested Edit-to-Tape via RS-422 & unable to perform insert edit
    Assemble edit seems fine
    Hence using FireWire for remote now, however there’s an issue with timecode drift, during insert edit
    May I know whats the best way to setup remote control for AJ-SD93 VTR ?
    Cheers
    Ben Cheng
    The Media Village
    Ben Cheng replied 20 years, 10 months ago 4 Members · 6 Replies
  • Jared Picune
    November 25, 2005 at 6:21 am
    I just rented the 93 deck two weeks ago. I was unable to get RS-422 control with my Kona 2 card. I just used firewire and that was that, other than an hour wasted thing to get the darn thing to work. I noticed that the 422 control was an option on the deck, so when I returned it to the shop I asked it they had that option installed. Well to make a long story short, they had no idea. However, they had every other option on that deck so I don’t know why they would not have the control. So I know that this does not answer your question, but I thought it might be interesting to you. And if you figure out a good setup for control with the 93, please let us know for future reference.
    Jared
    Idea Spring Editing, Inc.
    Denver Final Cut Pro UG
  • Jeff Bernstein
    November 25, 2005 at 9:24 am
    Actually, there is a fix for this. Call AJA support for the FCP patch. This patch is for SD Panasonic decks only.
    Jeff Bernstein
    Digital Desktop Consulting
    Apple Pro Video VAR
    XSAN Certified
    323-653-7611
  • Jan Crittenden livingston
    November 25, 2005 at 12:16 pm
    The AJ-SD93 does not do insert edits, there are no flying erase heads in this machine. Its bigger brother the AJ-SD930 can do what you want.
    Hope this helps,
    Jan
    Jan Crittenden Livingston
    Product Manager, DVCPRO, DVCPRO50, AG-DVX100
    Panasonic Broadcast & TV Systems
  • Ben Cheng
    November 28, 2005 at 11:40 am
    Hi guys
    Tks so much for your replies
    Jeff : Waiting for an reply from AJA now, with regards to the FCP patch
    Jan : May I know using FireWire as remote, is it possible to perform insert edit ?
    Cheers
    Ben
    The Media Village
    Singapore
    November 28, 2005 at 12:15 pm
    Ben,
    Insert Editing requires flying erase heads. The AJ-SD93 does not have these. The AJ-SD930 does, which is one of the reasons that it costs more.
    Best,
    Jan
  • Ben Cheng
    November 29, 2005 at 4:36 am
    Hi Jan
    Thanks for your clarification
    May I know for RS-422 remote, does it support Assembly mode for Edit-to-Tape ?
    Is there any limitation for RS-422 remote ?
    May I know if there’s any difference in using Firewire & RS-422 for remote ?
    Your advice is much appreciated !
    Cheers
    Ben Cheng
    The Media Village
    Singapore
