Activity › Forums › Apple Final Cut Pro Legacy › FCP 4.5 & Pan. AG-DV2000
Posted by Michael Allen on January 27, 2006 at 4:03 pmI cannot get device control of AG-DV200. Is it just me or will FCP not control this deck?
Jeff Carpenter replied 20 years, 7 months ago 2 Members · 3 Replies -
Jeff Carpenter
January 27, 2006 at 4:41 pmHa, yeah, it’s confussing. The switch that says “Passive” and two other settings and the litle turning knob to the left of it have to be set a certain way. Through trial and error I found the correct setting for capturing AND a different setting for editing/print-to-tape.
I made a sticker that tells me what to set it at and stuck it on my deck. Because of that I always just read it and can’t remember what the settings are! If no one else knows I will respond to this tonight when I get home, although it will be late.
So either wait until tomorrow morning to get my reply or you can start experimenting. I figured it out eventually but that’s the only way I figured it out. I could never find any documentation that spelled it out clearly.
Michael Allen
January 27, 2006 at 10:32 pmThanks, I will be glad to get the setting. I will check posts in the morning. Thanks again!
Jeff Carpenter
January 28, 2006 at 6:58 amOk, here’s what works for me:
EDITING/PLAYBACK = Dial on DV, Switch on RECORD
LOGGING/CAPTURE = Dial on DV, Switch on PASSIVEI hope that works for you too! I know that mine had its firewire board replaced before I got it, so hopefully that doesn’t affect this. Good luck.
