Activity Forums Apple Final Cut Pro Legacy FCP 4.5 not reading camera
  • FCP 4.5 not reading camera
    Posted by Ben Baudhuin on February 18, 2006 at 1:16 am
    I am trying to capture using FCP 4.5 and a Panasonic DVX 100A When I start up fcp it is not reading the external device, however when I open the capture window it gives me control of the camera ie.. fast fwd rwd play and it plays on the camera. So it’s controlling the cam but no picture is visible in the capture window. I tried deleting preferences and messing with my settings in fcp, also I have captured something with the same model camera on my computer, but not this exact cam. Are there any camera/computer settings I’m overlooking? Also the system profiler sees the camera is connected. it reads it and says there is a panasonic connected. So I’m stumped. can anyone help?
    thanks Ben Baudhuin
    Ben Baudhuin replied 20 years, 7 months ago 2 Members · 4 Replies
  • Jerry Hofmann
    February 18, 2006 at 4:00 am
    Might try trashing preferences in case they are corrupt, or there’s a read here on this: https://docs.info.apple.com/article.html?artnum=301852
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Ben Baudhuin
    February 18, 2006 at 4:22 pm
    I tried trashing the preferences already, it was one of the first things that I tried. I will try the quicktime but I am already running the newest version of it. Could it be the camera? Or does QT7 not run well with FCP 4.5?
  • Jerry Hofmann
    February 19, 2006 at 1:05 pm
    I think FCP 4.5 runs best in QT 6.5.2… but i’ve seen it run OK with 7… Do the reinstall and see if indeed it helps.
    Jerry
  • Ben Baudhuin
    February 19, 2006 at 10:48 pm
    Ok thanks for the help I appreciate it.
    Ben Baudhuin
