Activity › Forums › Apple Final Cut Pro Legacy › FCP 4.5, I can’t hear Audio during preview in “Log/Capture”
Posted by Delano Bryant on August 18, 2005 at 10:27 pmI am capturing from a Sony DVX 2000, I see the picture fine but I don’t hear anything. the audio meters in FCP are moving like there is audio there. My setting for capture is A and V. Help!
Delano Bryant replied 21 years, 1 month ago 3 Members · 5 Replies -
Miklos Philips
August 19, 2005 at 1:12 amThis is a common issue. It’s in the capture preferences somewhere, like “play through audio” buried… bad on Apple’s part… or should we say a bad Apple? look for it
Point Zero Pictures
https://www.pointzeropictures.com -
Miklos Philips
August 19, 2005 at 3:38 am -
Bouncing Account needs new email address
August 19, 2005 at 11:39 amThe audio is, by default, MUTED to the Mac’s speaker output during Log and Capture.
You should normally monitor the audio directly from the camcorder or deck you are using to capture (it is the preferred method).
CAUTION:
Many people have reported that noise or “pops” appear in the captured clips if the Mac’s internal audio is left on WHILE capturing… so may want to choose “Off During Capture.”However, there is a way you can turn ON the Mac’s speaker if you really WANT to:
Final Cut Pro (menu) > Audio/Video Settings… > Capture Presets (tab)
“Duplicate” the Capture Preset you are now using, when the window opens rename it (I added “MacAudioOn” to the file name).
Click open the “Advanced” button in the Audio section and turn speakers to “ON during Capture.”
The Mac speakers/audio-out will now play Audio during the preview in the Log and Capture window.
