Activity Forums Apple Final Cut Pro Legacy FCP 4.5 capture problems
  • FCP 4.5 capture problems
    Posted by Tomislav Rukavina on December 13, 2007 at 1:03 pm
    Hi all,
    here’s my issue:
    I’m running FCP 4.5 on a G5 2.0 dual 2.5 GB RAM / BM Deck Link Extreme PCI / system 10.4.11 / QT 7.3 Pro.
    I am having trouble capturing (digitizing) footage. It just does not work. After a few minutes the import just freezes, I have to restart my machine manually and throw away these big files that are created and take up the whole disk space. I updated my system only recently. While I was running under 10.3.9 with QT 6.5 everything was perfect.
    The problem persist no matter if I capture the footage via FW, SDI, component or composite to an internal, external FW800 or SCASI disk.
    From what I could add up I think it’s a software problem.
    Is it time to upgrade or is there a way to keep working with FCP 4.5?
    Could it be that the software combination is “lethal”?
    Any response would be of great help.
    THNX
    tom
    Tomislav Rukavina replied 18 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
