Activity Forums Apple Final Cut Pro FCE doesn’t import clips form canon Vixia HF S10 using log and transfer
  • FCE doesn’t import clips form canon Vixia HF S10 using log and transfer
    Posted by Ahabwe Mugerwa on October 14, 2011 at 2:29 am
    FCE doesn’t import clips form canon Vixia HF S10 using log and transfer. However when i connect the camera, i can view and download pictures but non of the video clips is available when camera is connected to m macbook pro
    Arthur Dobbe replied 14 years, 10 months ago 2 Members · 1 Reply
  • Arthur Dobbe
    October 15, 2011 at 7:57 pm
    I have a Vixia HF S100 (basically the same as S10) and no problems importing. I put the SD card in a SD card reader iso of connecting the camera itself.
    However the import dialog is very slow if you import from the SD card directly and some clips don’t import correctly on the first run.
    So I usually copy the entire card to my harddisk (also for backup purpose) and then import into FCP X from the copied archive.
