FCE 2-camera shoot rendering issue
Hi there,
I hope someone can help – I’m pulling my hair out here!
I have FC Express and want to do a 2 camera shoot using 2 SD card HD cameras. I plan to use a separate soundtrack, recorded at the time, onto a high quality recorder using some nicer mics than the camcorders. I’ll sync it up in the computer when I edit.
I can import the footage into FCE where it requires rendering. I render the files successfully. The problem is that when I move one of the files into another video track it needs to be re-rendered. In fact, with 2 video tracks stacked up I have to re-render whenever I move anything. Is there a way around this? Do I need Final Cut Pro?
Thanks in advance for your help,
Sam
