Activity Forums Apple Final Cut Pro Legacy FC widescreen filter problem
  • FC widescreen filter problem
    Posted by Giuliano Bausano on January 12, 2011 at 4:51 pm
    it’s my 1st post so i hope i am writing in the right place and respecting all the rules 😀
    ahem, anyway.. i am using FC and i’ve put “2:35 widescreen filter” to a clip to add a kind of letterbox but as i scale it up, into motion panel, to cut off a part of the image i don’t like, the letterbox also scale up and go outside of the screen.. is it normal? did i miss something? any idea, suggestion, pls?
    Giuliano Bausano replied 15 years, 8 months ago 2 Members · 4 Replies
  • Russell Lasson
    January 12, 2011 at 5:13 pm
    I would suggest adding a black matte on the video track above the clip. Add the wide screen filter to that. Then the matte will add the cropping to the clip below and you can still change the scale of the clip without changing the matte.
    Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
  • Giuliano Bausano
    January 13, 2011 at 1:55 pm
    Fast and Easy! Tnx a LOT 😀
    Wondering why i didn’t think about it :p
  • Giuliano Bausano
    January 15, 2011 at 11:55 am
    ehm, there must be something i am missing..
    excuse me pls i did few test but applying a black matte as it would be a layer above my clip, adding widescreen filter, CUT borders of the matte as result i see a black matte without top and bottom borders, like i’ve cropped the matte.. where’s my mistake? 🙂
    tnx in advance.
    rISO3D
  • Giuliano Bausano
    January 15, 2011 at 2:02 pm
    Thx a lot for the suggestion,
    i did some tests and still got some problems
    as i add a black matte above the clip with widescreen filter,
    i got a black matte COVERING the part of the video i need and leaving visible borders,
    what i would like to do is VICEVERSA but i still can’t find how to do it..
    where i did wrong?
    any idea pls?
    tnx in advance,
    rISO3D
