Activity Forums Apple Final Cut Pro Legacy fastest route for DVD copy of P2 original
  • fastest route for DVD copy of P2 original
    Posted by Erik Bannenberg on September 29, 2009 at 12:32 pm
    Iv’e shot on P2 and would like to make a timecoded DVD copy for my client.
    To facilitate that I’ve created timelines with a TCR filter on them.
    What would be the fastest route to compress these timelines out of FCP into ???
    Toast? iDVD? DVDStudioPro?
    It is about 4,5 hours of material… 🙁
    Working on a MacBookPro 2,5 Ghz, 512Mb video
    FCP 6 (Studio 2)
    Stuart Simpson replied 16 years, 11 months ago 4 Members · 5 Replies
  • Alex Elkins
    September 29, 2009 at 5:21 pm
    Hi Erik,
    Do you have a Kona card and a standalone DVD recorder? If so, the Kona card can output with a TC reader, which you run straight into your DVD recorder. It saves on a LOT of rendering because it does everything in realtime. Of course, the edit suite is out of action while this is going on though.
    If you have to do this in software, render the clips with the TC reader, then export a Quicktime reference file, and bring that into Compressor. From there you can apply one of the DVD presets, then create the DVD in DVD Studio Pro.
    One quick suggestion here, if you’re stuck doing this with FCP/Compressor/DVDSP: As this is presumably for your client to pick out TCs for a rough cut, you might consider setting your timeline to render in lower resolution & frame rate, in the Sequence Settings tab. This will seriously speed up the rendering in FCP, and for preview purposes it should be fine.
    All the best,
    Alex Elkins
  • Erik Bannenberg
    September 29, 2009 at 7:25 pm
    thank you!
  • Steve Eisen
    September 29, 2009 at 7:45 pm
    Imagine Products has what you need.
    1. Shotput Pro
    2. ProxyMill (faster than your current workflow)
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Erik Bannenberg
    September 29, 2009 at 8:44 pm
    do you have experience with this Shotput Pro?
    Can I also use it AFTER transferring to FCP?
  • Stuart Simpson
    September 30, 2009 at 1:44 pm
    [Erik Bannenberg] “To facilitate that I’ve created timelines with a TCR filter on them.”
    You can skip this step – compressor can add a BITC during compression.
    -Simmie
    6 MacPros – Kona 3 & Kona LH
    1 G5s – Kona LH
    xbox360, Wii, PSP, PS3
    https://www.speak.co.uk
