Activity Forums Apple Final Cut Pro Legacy Fastest .mov to .flv converter on a mac?
  • Fastest .mov to .flv converter on a mac?
    Posted by Clifton Long on July 22, 2009 at 1:29 am
    Hi, I have an upcoming project that requires me to convert about 20 1-hour clips (DV NTSC .mov format) to .flv flash video. Can anyone recommend the fastest conversion software or conversion method for a project like this?
    Thank you so much for the help!
    Acantony Clark replied 14 years ago 8 Members · 7 Replies
  • 7 Replies
  • Steve Eisen
    July 22, 2009 at 1:57 am
    Telestream Episode Pro.
    Matrox Compress HD will create a mov file that will work in Flash and playback in Flash player.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Ernie Santella
    July 22, 2009 at 2:27 am
    I 2nd Telestream Episode Pro. I have it and it smokes, really fast.
    Ernie Santella
    Santella Productions Inc.
    http://www.santellaproductions.com
  • Josh Olenslager
    July 22, 2009 at 3:53 am
    third on Episode Pro. It’s an animal.
    Josh
    Digital Media, Thought Equity Motion
  • Tom Brooks
    July 22, 2009 at 11:13 am
    As Steve implied Adobe has fully integrated H.264 into Flash, so hardware encoders that get you that can speed things up. Microsoft Silverlight has also adopted H.264. Look at their sites to get specifics on the exact specs accepted.
  • John Fishback
    July 22, 2009 at 5:00 pm
    Episode Pro is a fine encoder, but it costs. You already have Compressor. If you make an H.264 at the size and data rate you need with Compressor and then change the extension from .mov to .flv you’re done. Compressor can use all 8 cores of a Mac Pro and is very quick.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Ember Tramp
    April 21, 2010 at 10:31 am
    What for me,I use Macvide VideoFlash Converter.It’s soft for convert avi to flv.It’s helps me a lot.)
  • Acantony Clark
    September 3, 2012 at 6:06 am
    In order to convert MOV to FLV video, you must have FLV Converter for Mac OS X. After that you can follow the user guide to convert the video. However, if you want fastest video conversion then you will need to configure some conversion settings such as frame size, frame rate, audio codec, bit rate etc. After adjusting these settings, you can achieve fastest mov to flv conversion. For more details see https://flvconvertermacosx.com
