Activity Forums Compression Techniques Fastest Compression from FCP (not bothered about quality)
  • Fastest Compression from FCP (not bothered about quality)
    Posted by Jen Dunbar on April 11, 2008 at 12:09 pm
    Hey.
    Just wondering if anyone knows the quickest way to export a sequence from Final Cut Pro to final burn out to DVD. I need to make DVDs with timecode to be transcripted, so the quality isn’t important as long you can see and hear what people are saying.
    I’ve exported the sequence as a DV Quicktime file, then tried both iDVD (one step from Movie option), and Compressor (DVD 4:3 150mins Fastest Encode) and both seem to take forever.
    I’ve also tried exporting the sequence and bringing it straight into DVD Studio Pro but this is taking an age a well.
    I guess my question is, if I export the sequence as a reference (not self contained) file from Final Cut, what is the best setting to use in Compressor to produce a quick output file which I can bring in to DVD Studio Pro?
    Any help on this would be great.
    (NB I’m using Final Cut Pro 5.1.4 and Compressor 2.3)
    Jen Dunbar replied 18 years, 5 months ago 2 Members · 2 Replies
  • Craig Seeman
    April 11, 2008 at 1:45 pm
    Export Quicktime Reference Movie. Set iDVD pref to “Best Performance.”
    If you go the Compressor to DVD Studio Pro route set Compressor to use One Pass CBR (or VBR for a more potential quality).
    Use 8 Core Mac with healthy amount of RAM. Alas if time is money the cost of CPU vs time needed is a factor when making such compression/business decisions.
    If they’re going to be using a computer to view, consider making a one pass encode to WMV or MPEG4 (H.264 MOV will be slower) if that’s an option. MPEG1 might even work fine in this type of situation.
  • Jen Dunbar
    April 11, 2008 at 3:31 pm
    Thanks for that. I went for MPEG1 (with separate dolby audio) in the end. It was v quick, seems to work fine and also results in a pretty small file.
    Cheers.
