Activity › Forums › VEGAS Pro › Fastest and Easiest way to COLOUR CORRECT two clips to the same shade and all that
Posted by Anthony Christopher on June 28, 2011 at 7:50 amhey,
looking for any quick, viable way to colour correct to clips to be similar to each other.
really appreciate it.
any tips or tricks will do
“The Screen is a Magic Medium” – Kubrick
Ken Mitchell replied 15 years, 3 months ago 5 Members · 4 Replies -
Al Bergstein
June 28, 2011 at 7:40 pmAnthony, do you mean to clips of the same camera and scene, broken up, or do you mean two different scenes? For color correcting many short clips from the same camera and same ‘take’ (like in doing multicamera editing), you can color correct your first take, and when you go to paste on the subsequent clips, right click and choose paste event attributes (if I am remembering the right menu name). This pastes just the attributes of the clip, like color correction, as opposed to the clip itself.
hope this helps.
Alf
Stephen Mann
June 29, 2011 at 2:06 am -
Shawn Bossick
June 29, 2011 at 5:40 pmwithout a doubt for me, use the plug-in CHANNELS
the capability’s are AMAZING, & of course levels is a must! with your scopes.you will have to pull up your help files on Vegas & search for the plug-in CHANNELS there it will give you the information you need to learn this GREAT FEATURE
most likely this will take you some time to learn HOWEVER once you have learned this plug-in then you will be recommending it too.
Ken Mitchell
June 30, 2011 at 5:31 pmI would suggest that you use your scopes and color correct using the cc plugins.. Just match the scopes.Scopes do not lie, they are much more accurate than the eye even your screen is a High End calibrated unit.
