Activity Forums Apple Final Cut Pro Legacy Faster Workflow For Long Form Vids on FCP
  • Faster Workflow For Long Form Vids on FCP
    Posted by Kyle Macdonnell on July 25, 2010 at 8:23 pm
    Hey Guys,
    I was going to wait until after I’ve finished my first FCP project, but I have time because FCP is hung up over this spot on my timeline it doesn’t like. Here goes:
    2.8Ghz i7 iMac w 8 Gb Ram
    Firewire 800 HD’s
    Final Cut Pro 7.0.2
    I did a 2 camera HD shoot of a stage show; = 5 hours of .mov/.mts files + a 3 hour .wav sound file. About 100 Gb of files.
    It took days to turn this into Apple ProRess 422 & then it choked my system. I converted down to SD lossless, but this chokes also. Rendering takes forever. There are a couple of spots on my timeline that freeze up.
    My question is How can I work faster?
    Any help would be appreciated!
    Chris Tompkins replied 16 years, 2 months ago 2 Members · 3 Replies
  • Chris Tompkins
    July 25, 2010 at 10:43 pm
    What are you shooting on?
    What format are u capturing on the shoot?
    Did you use “Log & Transfer” to ingest the material?
    Chris Tompkins
    Video Atlanta
  • Kyle Macdonnell
    July 26, 2010 at 3:43 am
    I didn’t “Log & Transfer”. I shot .mov files on a T2i, 1080p @ 30fps & .mts on a Canon HF S100. The .mts files I first converted to H.264 using Adobe Media Encoder, but about 3 of the files crashed FCP, so I wound up using iSkysoft to convert to H.264, then I converted everything in Compressor to ProRes 422 LT. After I decided that HD might be too much for my setup, I down-converted to SD widescreen lossless QT in Media Encoder (this actually made the files much bigger)………………..
  • Chris Tompkins
    July 26, 2010 at 1:14 pm
    H.264 is NOT an editing codec. Don’t convert to that for editing.
    ProRres is a great way to go.
    I would take your original mov files on a T2i, 1080p @ 30fps & .mts on a Canon HF S100 and run them thru compressor and convert all to one format. Whether that’s HD or SD is up to you. If file size is an issue I would convert all to DV50 SD animorphic.
    OR
    Edit native w/ mov files from the T2i, 1080p @ 30fps and convert the mts to mov files 1080p @ 30fps
    OR
    But don’t convert to H.264 and then to something else that’s twice the compression.
    Chris Tompkins
    Video Atlanta
