Activity › Forums › Apple Final Cut Pro Legacy › Faster Rendering FCP?!???!?
  • Rafael Amador
    September 12, 2009 at 7:18 am
    As John points, the codec must be installed otherwise you couldn’t read neither export DVCProHD.
    It sounds more an AE issue. trash the AE preferences.
    You should also see which kind of codec you are using with FC. A one minute DVCProHD file it can not take 1 GB.
    Pic the papers and read a bit about workflow, codecs, exports,..
    rafael
    http://www.nagavideo.com
  • Kamal Bayy
    September 13, 2009 at 8:19 pm
    thank you but is there a way that i can reduce the size of the file when using the render queue without reducing the file quality?
    kamal
    Kamal
  • David Roth weiss
    September 13, 2009 at 8:39 pm
    [Kamal Bayy] “is there a way that i can reduce the size of the file when using the render queue without reducing the file quality? “
    Kamal,
    Quality is directly proportional to the amount of information contained in a file, and more information means increased file size.
    If you render at a lower resolution you can reduce both file size and render time, but quality will also be reduced accordingly.
    The laws of psychics and math do apply…
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Arnie Schlissel
    September 15, 2009 at 4:21 am
    [David Roth Weiss] “The laws of psychics and math do apply…”
    Darn!
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
Page 2 of 2
