Activity Forums Apple Final Cut Pro Legacy Faster exports for online review
  • Faster exports for online review
    Posted by Dennis Dean
    on September 19, 2011 at 1:58 pm
    I’m wondering if there is a faster way for me to export a video for interim review online? I’m currently using FCP 6.06 G5 Dual with 4 gigs of RAM and a two-drive external RAID ARAY connected via FW800.
    My usual process is to first export a reference copy (same settings as sequence – usually Pro Res 422 or XD Cam both 1080i), then compress it for online use. The problem is exporting from Final Cut (not compressing for online use.)
    Sometimes FCP exports a true reference copy, quickly, and sometimes FCP decides to export a self-contained version and take a lot of time, regardless of whether I’ve checked “self contained” or not. This is not much of a problem with most videos in the 2-4 minute ranges; my usual product.
    Recently two 25-minute videos have been problematic. This morning I went to export a reference copy and was informed it was an 11 hour process. I removed empty tracks and decided to export via Quick Time Conversion – outputting a half-size h.264 version. The dialogue box at first said 7 minutes, but at 7 percent completed decided 3 hours was more likely… and seems to be holding there. Far better than 7 percent.
    Any thoughts as to how to speed things up will be appreciated. I’ve been considering a new desktop because I need one for many reasons – but are there other formats or processes I should be looking at for this particular issue? I just want a faster way to spit out a version for the client to eye-ball in review.
    Dennis Dean
    The Dean Group
    -It’s about results-
    http://www.deangroup.com
    Jeremy Doyle replied 15 years ago 4 Members · 10 Replies
  • 10 Replies
  • Shane Ross
    September 19, 2011 at 2:05 pm
    Everything fully rendered before you export? If not, FCP renders as it exports. And that takes time
    Shane
  • Dennis Dean
    September 19, 2011 at 2:38 pm
    Hi Shane – as far as I know. I hit Sequence>Render All and lots of checked things show up – then it renders for awhile, then it’s done and plays back. … Hmmm.
    Just noticed “Full” was not checked – so I checked it and hit Render All again – it now says it’s “Conforming MPEG-2 Video…” and that the estimated time is 5 hours.
    I’ve never checked “Full” before… should I be doing this?
    Back to my original problem – at present just looking for a quicker method to export intermediate review copies.
    BTW – I hit “unsubscribe” by mistake – can you re-subscribe me or is that something I can do?
    thanks-Dennis (dennis@deangroup.com)
    Dennis Dean
    The Dean Group
  • Shane Ross
    September 19, 2011 at 3:16 pm
    Try to avoid using an XDCAM sequence setting…that’s where the CONFORMING part comes into action. Use a ProRes sequence, and render. Then export. NO conforming then. That’s the big problem, GOP timeline.
    Shane
  • Dennis Dean
    September 19, 2011 at 3:32 pm
    Aha! Thank you – And – anything faster than a straight export from FCP in the Pro Res sequence? (Such as via QT Conversion)
    And in my next system – would any kind of hardware help?
    DD
    Dennis Dean
    The Dean Group
  • Shane Ross
    September 19, 2011 at 3:35 pm
    [Dennis Dean] “nything faster than a straight export from FCP in the Pro Res sequence? (Such as via QT Conversion) “
    Nope. Fastest way is to fully render, export a ref QT, and take that into Compressor.
    [Dennis Dean] “And in my next system – would any kind of hardware help? “
    To render to H.264? Yes. Matrox Compress HD card (PCIe only), Matrox MXO2 Mini with MAX (any Matrox MXO2 product with MAX), Elgato Turbo.264 USB device…
    Shane
  • Dennis Dean
    September 19, 2011 at 3:42 pm
    Thanks very much. As always, invaluable advice – ! Saving your advice and my sheckels for the next system.
    DD
    Dennis Dean
    The Dean Group
  • Jeremy Doyle
    September 19, 2011 at 4:34 pm
    I have a 6 year old dual 2.3 G5 that I use at home and all I can say it that Elgato Turbo.264 USB device that I paid $75 bucks for has been done wonders for making on-line approvals and quick h.264 compressions that I have needed. Almost real-time conversations, which is amazing on a G5.
    The trick is finding an older model Elgato that will work with a G5. And the G5 version only creates SD frame sizes so if you need HD web files, your best bet is a new computer.
  • Dennis Dean
    September 19, 2011 at 6:49 pm
    Thanks, Jeremy – no, I do need HD sizes.
    Dennis Dean
    The Dean Group
  • Steve Eisen
    September 20, 2011 at 4:24 am
    Use the Turbo.264HD (HD version). $99
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Jeremy Doyle
    September 20, 2011 at 3:12 pm
    [Steve Eisen] “Use the Turbo.264HD (HD version). $99”
    That version is intel mac only and will not work with a G5.
